The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
disk.encryptsupportreqd events
Creating your file...
Your file is ready
disk.encryptSupportReqd
- Severity
ALERT
- Description
This message occurs when ONTAP® software detects one or more nonencrypting drives or non-FIPS-certified self-encrypting drives (SEDs), but the environment variable 'bootarg.storageencryption.support' is set to "true" to indicate that all drives must be FIPS-certified.
- Corrective Action
Remove all non-FIPS-certified SEDs and standard drives.
- Syslog Message
Detected nonencrypting drive or non-FIPS-certified drive %s, but only FIPS-certified drives are supported on this node. %d of %d drives checked are FIPS-certified.
- Parameters
disk (STRING): Name of a drive that is not FIPS-certified.
encrypting_disks (INT): Number of FIPS-certified drives detected.
disk_count (INT): Total number of drives checked. For a high-availability pair, this might be fewer than the total number of drives.
