scsiblade.import events
scsiblade.import.attr.mod
- Severity
ERROR
 - Description
This message occurs when attributes of a SAN LUN under LUN import are modified. This is not a supported operation and the LUN import session needs to be deleted and re-created.
 - Corrective Action
Run the "lun import delete" and "lun import create" commands to re-create the import session.
 - Syslog Message
Attributes of the following SAN LUN under LUN import are modified: Vserver %s, volume with MSID %llu, LUN serial number %s, LUN UUID %s. This is not a supported operation and the LUN import session needs to be deleted and re-created.
 - Parameters
vserver (STRING): Name or UUID of the Vserver.
volumeMSID (LONGINT): MSID of the container volume.
LUN_Serial (STRING): LUN serial number.
LUN_UUID (STRING): LUN UUID.
scsiblade.import.dblade.fail
- Severity
ERROR
 - Description
This message occurs when a SAN LUN import failover event fails for a Vserver during takeover or giveback. Some LUN import sessions configured on the Vserver will be affected. The failed LUN import sessions might not progress until a planned takeover or giveback is performed.
 - Corrective Action
Perform a planned takeover or giveback.
 - Syslog Message
SAN LUN import failover event failed for Vserver %s. Some LUN import sessions configured on the Vserver will be affected and will be in a failed state.
 - Parameters
scsiblade.import.lun.offline
- Severity
ERROR
 - Description
This message occurs when a LUN currently being imported is brought offline by Data ONTAP ® because of an I/O failure on the foreign disk. The issue is either that data cannot be read from or written to the source (foreign LUN), or that there is an internal error.
 - Corrective Action
Verify the connectivity to the foreign disk. After resolving any connectivity issues, delete the LUN import and create it again.
 - Syslog Message
LUN %s in volume with MSID %llu on Vserver %s has been brought offline due to an I/O failure on the underlying foreign disk with serial number %s.
 - Parameters
lunSerial (STRING): Serial number of the LUN.
volumeMSID (LONGINT): MSID of the volume.
foreignDiskSlNo (STRING): Serial number of the foreign disk.
scsiblade.import.volume.fail
- Severity
ERROR
 - Description
This message occurs when a SAN LUN import failover event fails for a volume during takeover or giveback. All LUN import sessions configured in this volume are affected. The failed LUN import sessions might not progress until a planned takeover or giveback is performed.
 - Corrective Action
 - Syslog Message
SAN LUN import failover event failed for Vserver %s, volume with MSID %llu. Some LUN import sessions configured on the volume will be affected and will be in a failed state.
 - Parameters
vserver (STRING): Name of the Vserver.
