ONTAP EMS reference
scsiblade.import events
scsiblade.import EMS events occur when ONTAP encounters issues associated with SAN LUN import operations.
scsiblade.import.attr.mod
Severity
ERROR
This message occurs when attributes of a SAN LUN under LUN import are modified. This is not a supported operation and the LUN import session needs to be deleted and re-created.
Corrective Action
Run the "lun import delete" and "lun import create" commands to re-create the import session.
Syslog Message
Attributes of the following SAN LUN under LUN import are modified: Vserver %s, volume with MSID %llu, LUN serial number %s, LUN UUID %s. This is not a supported operation and the LUN import session needs to be deleted and re-created.
vserver (STRING): Name or UUID of the Vserver.
volumeMSID (LONGINT): MSID of the container volume.
LUN_Serial (STRING): LUN serial number.
LUN_UUID (STRING): LUN UUID.
scsiblade.import.dblade.fail
Severity
ERROR
This message occurs when a SAN LUN import failover event fails for a Vserver during takeover or giveback. Some LUN import sessions configured on the Vserver will be affected. The failed LUN import sessions might not progress until a planned takeover or giveback is performed.
Corrective Action
Perform a planned takeover or giveback.
Syslog Message
SAN LUN import failover event failed for Vserver %s. Some LUN import sessions configured on the Vserver will be affected and will be in a failed state.
scsiblade.import.lun.offline
Severity
ERROR
This message occurs when a LUN currently being imported is brought offline by Data ONTAP ® because of an I/O failure on the foreign disk. The issue is either that data cannot be read from or written to the source (foreign LUN), or that there is an internal error.
Corrective Action
Verify the connectivity to the foreign disk. After resolving any connectivity issues, delete the LUN import and create it again.
Syslog Message
LUN %s in volume with MSID %llu on Vserver %s has been brought offline due to an I/O failure on the underlying foreign disk with serial number %s.
lunSerial (STRING): Serial number of the LUN.
volumeMSID (LONGINT): MSID of the volume.
foreignDiskSlNo (STRING): Serial number of the foreign disk.
scsiblade.import.volume.fail
Severity
ERROR
This message occurs when a SAN LUN import failover event fails for a volume during takeover or giveback. All LUN import sessions configured in this volume are affected. The failed LUN import sessions might not progress until a planned takeover or giveback is performed.
Corrective Action
Syslog Message
SAN LUN import failover event failed for Vserver %s, volume with MSID %llu. Some LUN import sessions configured on the volume will be affected and will be in a failed state.
vserver (STRING): Name of the Vserver.
