license.fpool events
Creating your file...
license.fpool.changed
- Severity
NOTICE
- Description
This message occurs when the maximum storage capacity limit for FabricPool is changed.
- Corrective Action
(None).
- Syslog Message
"FabricPool entitlement: maximum capacity limit now allows %u TB."
- Parameters
max_capacity (LONGINT): Current maximum limit supported under the current entitlement, in TB.
license.fpool.denied
- Severity
NOTICE
- Description
This message occurs when an attempt to alter the maximum storage capacity limit for FabricPool is denied by FabricPool.
- Corrective Action
(None).
- Syslog Message
"FabricPool entitlement: maximum capacity limit not changed to %u from %u TB."
- Parameters
requested_max_capacity (LONGINT): Requested maximum capacity supported, in TB.
current_max_capacity (LONGINT): Current maximum capacity limit supported under the current entitlement, in TB.
license.fpool.no.cloud
- Severity
NOTICE
- Description
This message occurs when an attempt to alter the maximum storage capacity limit for FabricPool is denied, because there is no support for licensing FabricPool directly on instances of Cloud ONTAP(tm).
- Corrective Action
(None).
- Syslog Message
"FabricPool entitlement: maximum capacity limit not changed to %u TB - licensing FabricPool directly on instances of Cloud ONTAP not supported."
- Parameters
license.fpool.removed
- Severity
NOTICE
- Description
This message occurs when the license for FabricPool usage is deleted.
- Corrective Action
(None).
- Syslog Message
"FabricPool entitlement deleted."
- Parameters
(None).
license.fpool.unsupported
- Severity
NOTICE
- Description
This message occurs when an attempt to alter the maximum storage capacity limit for FabricPool is denied, because FabricPool is not supported on this instance of ONTAP(tm).
- Corrective Action
(None).
- Syslog Message
"FabricPool entitlement: maximum capacity limit not changed to %u TB - feature is not supported."
- Parameters
license.fpool.wrong.cluster
- Severity
ERROR
- Description
This message occurs when an attempt to alter the maximum storage capacity limit for FabricPool is rejected. The license used in the attempt contains an incompatible cluster ID.
- Corrective Action
Determine the ID of the cluster by using the "cluster identity show" command. Within the license itself, determine the value of the "HostID" field. If the field exists, compare its value to the cluster ID. Confirm that these values match. If not, then the cluster is not the intended target of this license. Apply the license to the correct cluster if possible. For all other scenarios, contact NetApp technical support.
- Syslog Message
"FabricPool entitlement: maximum capacity limit not changed to %u TB; license applies to cluster with ID %s."
- Parameters
cluster_ID (STRING): Cluster ID as specified in license.
