ONTAP EMS reference
rdb.internal events
rdb.internal.error
Severity
ALERT
This message occurs when the cluster management Data Replication Module encounters an internal error, possibly causing the process to exit. The process should restart automatically, with full service restored.
Corrective Action
Verify that all the cluster management processes are running using the diagnostic command 'cluster ring show.' If not, contact NetApp technical support.
Syslog Message
Internal program error encountered: %s.
message (STRING): Error message.
