      rdb.internal events
rdb.internal.error
- Severity
ALERT
 - Description
This message occurs when the cluster management Data Replication Module encounters an internal error, possibly causing the process to exit. The process should restart automatically, with full service restored.
 - Corrective Action
Verify that all the cluster management processes are running using the diagnostic command 'cluster ring show.' If not, contact NetApp technical support.
 - Syslog Message
Internal program error encountered: %s.
 - Parameters
message (STRING): Error message.
