cpeer.create events
cpeer.create EMS events occur when ONTAP encounters issues associated with cluster peer reciprocal join operations.
cpeer.create.reciprocal.fail
- Severity
ERROR
- Description
This message occurs when a peer cluster reciprocal join fails.
- Corrective Action
Verify network connectivity between the local cluster and the peer cluster. Check the logs, trace buffers, and UI output for more information about the nature of the failure.
- Syslog Message
Cluster %s attempted to create a reciprocal peer relationship with this cluster but failed.
- Parameters
peer (STRING): Peer cluster which executed the reciprocal join.
cpeer.create.reciprocal.ok
- Severity
NOTICE
- Description
This message occurs when a peer cluster reciprocal join succeeds.
- Corrective Action
(None).
- Syslog Message
Cluster %s is now peered with this cluster.
- Parameters
peer (STRING): Peer cluster that executed the reciprocal join.
