ONTAP EMS reference
cpeer.create events
cpeer.create EMS events occur when ONTAP encounters issues associated with cluster peer reciprocal join operations.
cpeer.create.reciprocal.fail
Severity
ERROR
This message occurs when a peer cluster reciprocal join fails.
Corrective Action
Verify network connectivity between the local cluster and the peer cluster. Check the logs, trace buffers, and UI output for more information about the nature of the failure.
Syslog Message
Cluster %s attempted to create a reciprocal peer relationship with this cluster but failed.
peer (STRING): Peer cluster which executed the reciprocal join.
cpeer.create.reciprocal.ok
Severity
NOTICE
This message occurs when a peer cluster reciprocal join succeeds.
Corrective Action
(None).
Syslog Message
Cluster %s is now peered with this cluster.
peer (STRING): Peer cluster that executed the reciprocal join.
