The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
cpeer.create events
Creating your file...
Your file is ready
cpeer.create.reciprocal.fail
- Severity
ERROR
- Description
This message occurs when a peer cluster reciprocal join fails.
- Corrective Action
Verify network connectivity between the local cluster and the peer cluster. Check the logs, trace buffers, and UI output for more information about the nature of the failure.
- Syslog Message
Cluster %s attempted to create a reciprocal peer relationship with this cluster but failed.
- Parameters
peer (STRING): Peer cluster which executed the reciprocal join.
cpeer.create.reciprocal.ok
- Severity
NOTICE
- Description
This message occurs when a peer cluster reciprocal join succeeds.
- Corrective Action
(None).
- Syslog Message
Cluster %s is now peered with this cluster.
- Parameters
peer (STRING): Peer cluster that executed the reciprocal join.
