hotplug.generic events
hotplug.generic.busy_not_ready
Severity
ERROR
This message occurs when a module replacement or removal command fails because the driver or system is busy. Hot plug functionality is not available at this time.
Corrective Action
Try the command again after a few minutes. If the system remains busy, it is an internal error. Contact NetApp technical support for assistance.
Syslog Message
%s command failed for module %s in slot %s of node %s because the driver or system is busy.
command (STRING): Name of the command.
card (STRING): Name of the module.
slot (STRING): Number of the slot.
node (STRING): Name of the node.
