The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
hotplug.generic events
Creating your file...
Your file is ready
hotplug.generic.busy_not_ready
- Severity
ERROR
- Description
This message occurs when a module replacement or removal command fails because the driver or system is busy. Hot plug functionality is not available at this time.
- Corrective Action
Try the command again after a few minutes. If the system remains busy, it is an internal error. Contact NetApp technical support for assistance.
- Syslog Message
%s command failed for module %s in slot %s of node %s because the driver or system is busy.
- Parameters
command (STRING): Name of the command.
card (STRING): Name of the module.
slot (STRING): Number of the slot.
node (STRING): Name of the node.
