ONTAP EMS reference
fmmb.exthdr events
fmmb.exthdr.null
Severity
ERROR
This event is issued when the HA Mailbox extension header is invalid. The extension header is an on-disk structure which describes the opaque client blocks and major reset structures.
Corrective Action
(None).
Syslog Message
HA Mailbox extension header is null.
host (STRING): The node which owns the HA mailbox disk. The node can be either local or partner.
