fmmb.exthdr events
fmmb.exthdr.null
- Severity
ERROR
- Description
This event is issued when the HA Mailbox extension header is invalid. The extension header is an on-disk structure which describes the opaque client blocks and major reset structures.
- Corrective Action
(None).
- Syslog Message
HA Mailbox extension header is null.
- Parameters
host (STRING): The node which owns the HA mailbox disk. The node can be either local or partner.
