gpo.frmwork events
gpo.frmwork.RSoPApplied
Severity
NOTICE
This event occurs after the resultant set of Group Policy (GPO) is calculated and applied to the Replicated Database (RDB) successfully.
Corrective Action
(None).
Syslog Message
GPO policy applied into RDB successfully.
vserver (STRING): Vserver name.
gpo.frmwork.secJobFailed
Severity
ERROR
This message occurs when starting or restarting the GPO Security Apply job fails.
Corrective Action
Address the specific reason for the issue, and then start the job by entering the "vserver cifs group-policy update -force-reapply-all-settings true -vserver <vserver-name>" command.
Syslog Message
Failed to start a GPO Security Apply job run for Vserver %s, reason: %s.
reason (STRING): Reason for the failure.
gpo.frmwork.updateFailed
Severity
ERROR
This message occurs when updating group policy object (GPO) tables fails.
Corrective Action
Address the specific reason for the issue, and then update the tables by entering the "vserver cifs group-policy update -force-reapply-all-settings true -vserver <vserver-name>" command.
Syslog Message
GPO tables update failed for Vserver %s, reason: %s.
gpo.frmwork.updateRSoPFailed
Severity
ERROR
This message occurs when updating group policy object (GPO) RSoP (Resultant Set of Policy) settings fails.
Corrective Action
Address the specific reason for the issue, and then update the settings by entering the "vserver cifs group-policy update -force-reapply-all-settings true -vserver <vserver-name>" command.
Syslog Message
GPO RSoP update failed for Vserver %s, reason: %s.
