gpo.frmwork events
gpo.frmwork EMS events occur when ONTAP encounters issues associated with Group Policy Object (GPO) framework operations.
gpo.frmwork.RSoPApplied
- Severity
NOTICE
- Description
This event occurs after the resultant set of Group Policy (GPO) is calculated and applied to the Replicated Database (RDB) successfully.
- Corrective Action
(None).
- Syslog Message
GPO policy applied into RDB successfully.
- Parameters
vserver (STRING): Vserver name.
gpo.frmwork.secJobFailed
- Severity
ERROR
- Description
This message occurs when starting or restarting the GPO Security Apply job fails.
- Corrective Action
Check the CIFS configuration by running the "vserver cifs show -vserver <vserver-name>" and "vserver cifs check -vserver <vserver-name>" commands. Run the job again using the "vserver cifs group-policy update -force-reapply-all-settings true -vserver <vserver-name>" command.
- Syslog Message
Failed to start a GPO Security Apply job run for Vserver %s, reason: %s.
- Parameters
reason (STRING): Reason for the failure.
gpo.frmwork.updateFailed
- Severity
ERROR
- Description
This message occurs when updating group policy object (GPO) tables fails.
- Corrective Action
- Syslog Message
GPO tables update failed for Vserver %s, reason: %s.
- Parameters
gpo.frmwork.updateRSoPFailed
- Severity
ERROR
- Description
This message occurs when updating group policy object (GPO) RSoP (Resultant Set of Policy) settings fails.
- Corrective Action
- Syslog Message
GPO RSoP update failed for Vserver %s, reason: %s.
- Parameters
