adminapi.xml events
Creating your file...
Your file is ready
adminapi.xml.encoding
- Severity
ERROR
- Description
This event is generated in case of a mismatched XML encoding received by ONTAP server.
- Corrective Action
Correct the mismatched encoding and retry the API.
- Syslog Message
ONTAP server got unexpected encoding (expected %s, got %s
- Parameters
expEnco (STRING): The expected xml encoding.
recvEnco (STRING): The actual received encoding.
adminapi.xml.namespace
- Severity
ERROR
- Description
This event is generated in case of a mismatched xml namespace received by ONTAP server.
- Corrective Action
Correct the XML namespace and retry the API.
- Syslog Message
ONTAP server namespace (expected %s, got %s
- Parameters
expNamesp (STRING): The expected xml namespace.
uri (STRING): The received uri
