ONTAP EMS reference
adminapi.xml events
adminapi.xml EMS events occur when ONTAP encounters issues associated with mismatched XML encoding or namespace received by the ONTAP server.
adminapi.xml.encoding
Severity
ERROR
This event is generated in case of a mismatched XML encoding received by ONTAP server.
Corrective Action
Correct the mismatched encoding and retry the API.
Syslog Message
ONTAP server got unexpected encoding (expected %s, got %s
expEnco (STRING): The expected xml encoding.
recvEnco (STRING): The actual received encoding.
adminapi.xml.namespace
Severity
ERROR
This event is generated in case of a mismatched xml namespace received by ONTAP server.
Corrective Action
Correct the XML namespace and retry the API.
Syslog Message
ONTAP server namespace (expected %s, got %s
expNamesp (STRING): The expected xml namespace.
uri (STRING): The received uri
