ONTAP EMS reference
adminapi.xml events
adminapi.xml.encoding
Severity
ERROR
This event is generated in case of a mismatched XML encoding received by ONTAP server.
Corrective Action
Correct the mismatched encoding and retry the API.
Syslog Message
ONTAP server got unexpected encoding (expected %s, got %s
expEnco (STRING): The expected xml encoding.
recvEnco (STRING): The actual received encoding.
adminapi.xml.namespace
Severity
ERROR
This event is generated in case of a mismatched xml namespace received by ONTAP server.
Corrective Action
Correct the XML namespace and retry the API.
Syslog Message
ONTAP server namespace (expected %s, got %s
expNamesp (STRING): The expected xml namespace.
uri (STRING): The received uri
