The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
adminapi.xml events
Creating your file...
Your file is ready
adminapi.xml.encoding
- Severity
ERROR
- Description
This event is generated in case of a mismatched XML encoding received by ONTAP server.
- Corrective Action
Correct the mismatched encoding and retry the API.
- Syslog Message
ONTAP server got unexpected encoding (expected %s, got %s
- Parameters
expEnco (STRING): The expected xml encoding.
recvEnco (STRING): The actual received encoding.
adminapi.xml.namespace
- Severity
ERROR
- Description
This event is generated in case of a mismatched xml namespace received by ONTAP server.
- Corrective Action
Correct the XML namespace and retry the API.
- Syslog Message
ONTAP server namespace (expected %s, got %s
- Parameters
expNamesp (STRING): The expected xml namespace.
uri (STRING): The received uri
