ONTAP EMS reference
raid.monitor events
raid.monitor EMS events occur when the hourly monitor indicates that the current aggregate or volume number exceeded the maximum number of supported volumes on the host.
raid.monitor.maxVols
Severity
ERROR
This message occurs when the hourly monitor indicates that the current aggregate or volume number exceeded the maximum number of supported volumes on the host.
Corrective Action
Check the number of volumes on the host. Destroy the newly created volume if the maximum for the total number of volumes on this host is exceeded.
Syslog Message
WARNING: There are too many (%d) volumes on the host. The limit is %d in %s configuration.
numVols (INT): Current number of volumes on the host.
maxVols (INT): Maximum number of volumes supported.
configType (STRING): Current configuration.
