      raid.monitor events
raid.monitor.maxVols
- Severity
ERROR
 - Description
This message occurs when the hourly monitor indicates that the current aggregate or volume number exceeded the maximum number of supported volumes on the host.
 - Corrective Action
Check the number of volumes on the host. Destroy the newly created volume if the maximum for the total number of volumes on this host is exceeded.
 - Syslog Message
WARNING: There are too many (%d) volumes on the host. The limit is %d in %s configuration.
 - Parameters
numVols (INT): Current number of volumes on the host.
maxVols (INT): Maximum number of volumes supported.
configType (STRING): Current configuration.
