The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
raid.monitor events
Creating your file...
Your file is ready
raid.monitor.maxVols
- Severity
ERROR
- Description
This message occurs when the hourly monitor indicates that the current aggregate or volume number exceeded the maximum number of supported volumes on the host.
- Corrective Action
Check the number of volumes on the host. Destroy the newly created volume if the maximum for the total number of volumes on this host is exceeded.
- Syslog Message
WARNING: There are too many (%d) volumes on the host. The limit is %d in %s configuration.
- Parameters
numVols (INT): Current number of volumes on the host.
maxVols (INT): Maximum number of volumes supported.
configType (STRING): Current configuration.
