ONTAP EMS reference
raid.unsupported events
raid.unsupported EMS events occur when ONTAP encounters issues associated with unsupported aggregate formats.
raid.unsupported.bitformat
Severity
ERROR
This message occurs when configuration management detects that the disk belongs to a 32-bit aggregate, the use of which has been deprecated. The disk is removed from service.
Corrective Action
Install a version of Data ONTAP® that supports the 32-bit aggregate, or remove the 32-bit aggregate disks.
Syslog Message
The label on %s indicates that the disk belongs to a 32-bit aggregate, the use of which has been deprecated.
disk_info (STRING): Information about the disk object, including disk name, path, shelf, bay, serial number, vendor, model, RPM, and carrier serial number.
shelf (STRING): Identifier of the shelf where the disk is located.
bay (STRING): Disk bay within the shelf where the disk is located.
vendor (STRING): Name of the vendor of the disk.
model (STRING): Model string of the disk.
firmware_revision (STRING): Firmware revision number of the disk.
serialno (STRING): Serial number of the disk.
disk_type (INT): Type of disk.
disk_rpm (STRING): Rotational speed of the disk, in RPM.
failure_reason (STRING): Text description of the storage error leading to disk failure.
carrier (STRING): Unique ID of the carrier in which the disk is installed.
site (STRING): For a MetroCluster(tm) configuration, indicates the site {Local|Remote} where the disk is located. For non-MetroCluster configurations, site is Local.
raid.unsupported.cksumtype
Severity
ERROR
This message occurs when configuration management detects that the disk belongs to a ZCS aggregate, the use of which has been deprecated. The disk is removed from service.
Corrective Action
Install a version of Data ONTAP® that supports the ZCS aggregate, or remove the ZCS aggregate disks.
Syslog Message
The label on %s indicates that the disk belongs to a ZCS aggregate, the use of which has been deprecated.
