nvmeof.hostport events
Creating your file...
nvmeof.hostport.clear
- Severity
NOTICE
- Description
This message occurs when a node shelf is no longer cabled incorrectly from a port that is not a storage port. Indicates condition has cleared.
- Corrective Action
(None).
- Syslog Message
Shelf on node %s with SN %s is no longer cabled incorrectly from a port that is not a storage port.
- Parameters
node_name (STRING): Host name connected to the cable.
shelf_sn (STRING): Serial number of the shelf connected to the cable.
nvmeof.hostport.error
- Severity
ERROR
- Description
This message occurs when the host port is incorrectly cabled to the shelf.
- Corrective Action
Reconnect the host port to a Storage Ethernet port.
- Syslog Message
Port %s is not configured as a Storage Ethernet port on node %s. It is incorrectly cabled to Shelf with SN %s.
- Parameters
host_port (STRING): Host port connected to the cable.
