nvmeof.hostport events
nvmeof.hostport.clear
Severity
NOTICE
This message occurs when a node shelf is no longer cabled incorrectly from a port that is not a storage port. Indicates condition has cleared.
Corrective Action
(None).
Syslog Message
Shelf on node %s with SN %s is no longer cabled incorrectly from a port that is not a storage port.
node_name (STRING): Host name connected to the cable.
shelf_sn (STRING): Serial number of the shelf connected to the cable.
nvmeof.hostport.error
Severity
ERROR
This message occurs when the host port is incorrectly cabled to the shelf.
Corrective Action
Reconnect the host port to a Storage Ethernet port.
Syslog Message
Port %s is not configured as a Storage Ethernet port on node %s. It is incorrectly cabled to Shelf with SN %s.
host_port (STRING): Host port connected to the cable.
