The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
config.nocheck events
Creating your file...
Your file is ready
config.NoCheck
- Severity
NOTICE
- Description
This message occurs when the system should be halting, but it cannot because the "no-config-check? " environment variable is set to true.
- Corrective Action
(None).
- Syslog Message
This is an illegal configuration. However the Filer is not halting due to no-config-check? being set to true.
- Parameters
(None).
