The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
disk.timeout events
Creating your file...
Your file is ready
disk.timeout.flush.end
- Severity
NOTICE
- Description
This message occurs when the disk driver stops flushing aggressive timeout I/Os.
- Corrective Action
(None).
- Syslog Message
Aggressive timeout flush ended on disk %s S/N %s.
- Parameters
disk_name (STRING): Name of the disk.
serial_num (STRING): Serial number of the disk.
disk.timeout.flush.start
- Severity
NOTICE
- Description
This message occurs when an I/O operation is taking longer than expected and aggressive timeout I/Os are flushed from the disk driver.
- Corrective Action
(None).
- Syslog Message
Aggressive timeout flush started on disk %s S/N %s. Details: %s.
- Parameters
details (STRING): Additional information.
