wafl.gd events
Creating your file...
wafl.gd.convert.scan.running
- Severity
NOTICE
- Description
This message occurs when converting a file to use granular data fails because a scanner is currently running on the volume. The conversion cannot be completed until the scan is complete or filesystem inconsistencies can occur. Granular data conversion is required for non-disruptive file moves that occur as part of volume rebalancing.
- Corrective Action
Retry the operation after some time to allow the scan to complete. If the problem persists, contact NetApp technical support for assistance.
- Syslog Message
Granular data conversion failed for fileid "%d" on volume "%s%s%s%s" because scan "%s" is currently running on the volume.
- Parameters
fileid (INT): File identifier.
owner (STRING): Owner of the volume.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Volume identifier that uniquely identifies the volume in cases where the volume name itself is insufficient.
scantype (STRING): Type of scan.
wafl.gd.convert.unknown.pvbn
- Severity
NOTICE
- Description
This message occurs when converting a file to use granular data fails because the file contains unresolved physical block numbers (PVBNs). Unresolved PVBNs occur when you move a volume to a different aggregate. PVBNs are resolved by a background process following the volume move.
- Corrective Action
Retry the operation after some time to allow the background process to complete.
- Syslog Message
Granular data conversion failed for fileid "%d" on volume "%s%s%s%s" because the inode contains unresolved PVBNs.
- Parameters
