The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vsdr.fpvoldropqospolicy events
Creating your file...
Your file is ready
vsdr.FPVolDropQosPolicy
- Severity
NOTICE
- Description
This message occurs when the system clears or drops an incompatible quality of service (QoS) policy group setting with minimum throughput value set on a destination volume having tiering policy other than "none" on a FabricPool aggregate at the destination cluster.
- Corrective Action
(None).
- Syslog Message
QoS policy group with minimum throughput setting cannot be set on the volume "%s" on storage virtual machine (SVM) "%s" on a FabricPool aggregate having a tiering policy other than "none".
- Parameters
source_volume_name (STRING): Name of the source volume on FabricPool aggregate of SVM DR relationship.
src_vserver_name (STRING): Name of the source SVM.
