ONTAP EMS reference
arw.analytics events
arw.analytics.ext.report
Severity
NOTICE
This message occurs when anti-ransomware analytics generates or updates the "suspicious file extensions" report for a volume.
Corrective Action
(None).
Syslog Message
Anti-ransomware file extension analytics has found %s across high entropy data on the volume "%s" in Vserver "%s". Report location: %s.
fileExtension (STRING): Previously unseen file extension or suspicious file extension
volumeName (STRING): Name of the volume.
vserverName (STRING): Name of the Vserver.
fileExtensionReport (STRING): Link to report run after file extension analysis.
arw.analytics.high.entropy
Severity
ERROR
This message occurs when the number of high entropy data log messages (pertaining to ransomware detection and analysis) that were generated for a volume cross the predefined threshold.
Corrective Action
To correct this issue: 1) Restore data from the last Snapshot copy that were saved before high entropy data was detected. 2) Refer to the anti-ransomware documentation to learn how to implement ransomware protection and mitigation strategies.
Syslog Message
A large amount of high entropy data was found on volume "%s" in Vserver "%s".
arw.analytics.probability
Severity
ERROR
This message occurs when an anti-ransomware attack probability has changed from "low" to "high" on a volume.
Corrective Action
To correct this issue: 1) Restore to the last safe Snapshot copy before attack probabilty became high. 2) Refer to the anti-ransomware documentation to diagnose further and take remedial measures.
Syslog Message
Anti-ransomware attack probability changed from low to high on volume "%s" in Vserver "%s".
arw.analytics.report
Severity
NOTICE
This message occurs when an anti-ransomware analytics report is generated or updated for a volume.
Corrective Action
(None).
Syslog Message
Anti-ransomware analytics report has been generated for volume %s of Vserver %s. The report is available at %s.
report_path (STRING): Path to anti-ransomware report.
arw.analytics.suspects
Severity
ERROR
This message occurs when a list of suspects generated by anti-ransomware analytics grows to a point where further investigation is needed.
Corrective Action
(None).
Syslog Message
Anti-ransomware analytics on volume "%s" in Vserver "%s" has outstanding suspect files.
