The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
hybaggrcopy.dstgeommismatch events
Creating your file...
Your file is ready
hybAggrCopy.dstGeomMismatch
- Severity
ERROR
- Description
This message occurs when there is a mismatch between the disk geometries of source and destination hybrid aggregates.
- Corrective Action
Satisfy the following conditions: Both aggregates are hybrid. The destination aggregate has at least the same number of HDD and SSD disks as the source aggregate. The disk size and type of each disk of the source aggregate matches those of the destination aggregate.
- Syslog Message
Aggregate %s cannot be copied. Source and destination hybrid aggregate geometries do not match.
- Parameters
srcaggr (STRING): Aggr copy source aggregate.
