The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
netif.hangdetected events
Creating your file...
Your file is ready
netif.hangDetected
- Severity
ERROR
- Description
This message occurs when a network interface driver detects that an interface is hung.
- Corrective Action
If hardware is reset and there are no further hangs, no corrective action is required. Otherwise, if the system reports frequent hangs, a core dump is forced, or no action is taken by the driver, contact NetApp technical support.
- Syslog Message
Network interface %s hung (%s). %s. Driver: %s.
- Parameters
ifName (STRING): Name of the network interface: for example, "e4a".
hangType (STRING): Type of hang. For example, "transmit", "PCIe RcvMstAbt".
recoveryAction (STRING): Action, if any, that will be taken by the driver to recover. For example, "Resetting to recover" or "Forcing panic for core dump" (for root cause analysis).
driver (STRING): Driver name.
