ONTAP EMS reference
wafl.bad events
wafl.bad.aggr.buftree.type
Severity
EMERGENCY
This message occurs when you attempt to bring an aggregate online whose file system buftree type and RAID label format are inconsistent. Buftree type indicates whether the filesystem is a 32-bit or a 64-bit. Attempting to online this aggregate can cause data corruption or a system panic.
Corrective Action
Contact NetApp technical suppor
Syslog Message
Aggregate %s: Inconsistency found with the file system buftree type and RAID label format (large aggr: %d, fs: 0x%x, RAID: %d).
name (STRING): The aggregate name.
large (INT): Flag showing if the aggregate size is bigger than 16 TB.
fsbuftree (INT): File system buftree type.
raidfmt (INT): RAID buftree format.
wafl.bad.vol.buftree.type
Severity
EMERGENCY
This message occurs when you attempt to bring online a volume whose file system and volume descriptor buftree type show inconsistency. The buftree type shows whether the file system is a 32-bit or 64-bit. Bringing online such a volume can cause data corruption or system panic.
Corrective Action
(Call support).
Syslog Message
Volume %s: Inconsistency found with the file system buftree type and volume descriptor buftree type (large vol: %d, fs: 0x%x, label: 0x%x, RAID: %d). Bringing the volume online can cause data corruptions or system panic. Contact NetApp technical support.
volname (STRING): Volume name.
large (INT): Flag showing if the volume size is bigger than 16 TB.
labelfmt (INT): Volume descriptor buftree type.
raidfmt (INT): RAID buftree type.
