wafl.bad events
Creating your file...
wafl.bad.aggr.buftree.type
- Severity
EMERGENCY
- Description
This message occurs when you attempt to bring an aggregate online whose file system buftree type and RAID label format are inconsistent. Buftree type indicates whether the filesystem is a 32-bit or a 64-bit. Attempting to online this aggregate can cause data corruption or a system panic.
- Corrective Action
Contact NetApp technical suppor
- Syslog Message
Aggregate %s: Inconsistency found with the file system buftree type and RAID label format (large aggr: %d, fs: 0x%x, RAID: %d).
- Parameters
name (STRING): The aggregate name.
large (INT): Flag showing if the aggregate size is bigger than 16 TB.
fsbuftree (INT): File system buftree type.
raidfmt (INT): RAID buftree format.
wafl.bad.vol.buftree.type
- Severity
EMERGENCY
- Description
This message occurs when you attempt to bring online a volume whose file system and volume descriptor buftree type show inconsistency. The buftree type shows whether the file system is a 32-bit or 64-bit. Bringing online such a volume can cause data corruption or system panic.
- Corrective Action
(Call support).
- Syslog Message
Volume %s: Inconsistency found with the file system buftree type and volume descriptor buftree type (large vol: %d, fs: 0x%x, label: 0x%x, RAID: %d). Bringing the volume online can cause data corruptions or system panic. Contact NetApp technical support.
- Parameters
volname (STRING): Volume name.
large (INT): Flag showing if the volume size is bigger than 16 TB.
labelfmt (INT): Volume descriptor buftree type.
raidfmt (INT): RAID buftree type.
