ONTAP EMS reference
disk.dynamicqual events
disk.dynamicqual.fail.parse
Severity
ERROR
This message occurs when dynamic device qualification fails due to an invalid /etc/qual_devices file. The system is unable to properly recognize disk drives or fully enable all resiliency and performance features.
Corrective Action
For further information about correcting the problem, search the knowledgebase of the NetApp technical support support web site for the "[disk.dynamicqual.fail.parse]" keyword. Request an updated qual_devices file from NetApp.
Syslog Message
Device qualification information file (/etc/qual_devices) is invalid. The following error, "%s" has been detected. For further information about correcting the problem, search the knowledgebase of the NetApp technical support support web site for the "[disk.dynamicqual.fail.parse]" keyword.
errorstring (STRING): Error string for parsing error in /etc/qual_devices file.
disk.dynamicqual.failure.cleared
Severity
NOTICE
This message occurs when a previous dynamic device qualification error has been corrected.
Corrective Action
(None).
Syslog Message
Device qualification failure condition has been corrected. All devices have been qualified.
(None).
disk.dynamicqual.failure.invalidFile
Severity
ALERT
Corrective Action
See the qual_devices man page for information about updating device qualification data. Request an updated qual_devices file from NetApp.
Syslog Message
Device qualification information file (/etc/qual_devices) is invalid. See the qual_devices man page for corrective action. This problem must be corrected within %d hour(s) to avoid a forced system shutdown. The following disk(s) remain unqualified: %s.
time (INT): Time until forced shutdown.
disklist (STRING): List of disks that are still not qualified.
disk.dynamicqual.failure.missingFile
Severity
ALERT
This message occurs when dynamic device qualification fails with a missing qualification file.
Corrective Action
See the qual_devices man page for information about updating device qualification data. Request a qual_devices file from NetApp.
Syslog Message
Device Qualification information file (/etc/qual_devices) is missing. See the qual_devices man page for corrective action. This problem must be corrected within %d hour(s) to avoid a forced system shutdown. The following disk(s) remain unqualified: %s.
disk.dynamicqual.failure.occurred
Severity
ALERT
This message occurs when dynamic device qualification fails with an unknown error.
Corrective Action
Syslog Message
Device qualification failure occurred. See the qual_devices man page for corrective action. This problem must be corrected within %d hour(s) to avoid a forced system shutdown. The following disk(s) remain unqualified: %s.
disk.dynamicqual.failure.shutdown
Severity
EMERGENCY
This message occurs when one or more disks are not recognized by Data ONTAP®. This can result in a forced system shutdown if the offending disks are not removed or recognized properly within the allowed window of time.
Corrective Action
Download the latest Drive Qualification Package (DQP) from NetApp technical support, and then install it on your system.
Syslog Message
Device qualification failure has not been corrected for the past %d hour(s). The following disk(s) remain unqualified: %s. System is SHUTTING DOWN.
