disk.dynamicqual events
disk.dynamicqual.fail.parse
- Severity
ERROR
 - Description
This message occurs when dynamic device qualification fails due to an invalid /etc/qual_devices file. The system is unable to properly recognize disk drives or fully enable all resiliency and performance features.
 - Corrective Action
For further information about correcting the problem, search the knowledgebase of the NetApp technical support support web site for the "[disk.dynamicqual.fail.parse]" keyword. Request an updated qual_devices file from NetApp.
 - Syslog Message
Device qualification information file (/etc/qual_devices) is invalid. The following error, "%s" has been detected. For further information about correcting the problem, search the knowledgebase of the NetApp technical support support web site for the "[disk.dynamicqual.fail.parse]" keyword.
 - Parameters
errorstring (STRING): Error string for parsing error in /etc/qual_devices file.
disk.dynamicqual.failure.cleared
- Severity
NOTICE
 - Description
This message occurs when a previous dynamic device qualification error has been corrected.
 - Corrective Action
(None).
 - Syslog Message
Device qualification failure condition has been corrected. All devices have been qualified.
 - Parameters
(None).
disk.dynamicqual.failure.invalidFile
- Severity
ALERT
 - Description
 - Corrective Action
See the qual_devices man page for information about updating device qualification data. Request an updated qual_devices file from NetApp.
 - Syslog Message
Device qualification information file (/etc/qual_devices) is invalid. See the qual_devices man page for corrective action. This problem must be corrected within %d hour(s) to avoid a forced system shutdown. The following disk(s) remain unqualified: %s.
 - Parameters
time (INT): Time until forced shutdown.
disklist (STRING): List of disks that are still not qualified.
disk.dynamicqual.failure.missingFile
- Severity
ALERT
 - Description
This message occurs when dynamic device qualification fails with a missing qualification file.
 - Corrective Action
See the qual_devices man page for information about updating device qualification data. Request a qual_devices file from NetApp.
 - Syslog Message
Device Qualification information file (/etc/qual_devices) is missing. See the qual_devices man page for corrective action. This problem must be corrected within %d hour(s) to avoid a forced system shutdown. The following disk(s) remain unqualified: %s.
 - Parameters
disk.dynamicqual.failure.occurred
- Severity
ALERT
 - Description
This message occurs when dynamic device qualification fails with an unknown error.
 - Corrective Action
 - Syslog Message
Device qualification failure occurred. See the qual_devices man page for corrective action. This problem must be corrected within %d hour(s) to avoid a forced system shutdown. The following disk(s) remain unqualified: %s.
 - Parameters
disk.dynamicqual.failure.shutdown
- Severity
EMERGENCY
 - Description
This message occurs when one or more disks are not recognized by Data ONTAP®. This can result in a forced system shutdown if the offending disks are not removed or recognized properly within the allowed window of time.
 - Corrective Action
Download the latest Drive Qualification Package (DQP) from NetApp technical support, and then install it on your system.
 - Syslog Message
Device qualification failure has not been corrected for the past %d hour(s). The following disk(s) remain unqualified: %s. System is SHUTTING DOWN.
 - Parameters
