ONTAP EMS reference
netif.sfpeventerrorcode events
netif.sfpEventErrorCode
Severity
ERROR
This message occurs when the installed Small Form-factor Pluggable (SFP+ or QSFP+) module is either not supported or faulty.
Corrective Action
The cable could be unsupported or faulty. Replace the cable and check the switch port configuration for errors.
Syslog Message
Unsupported or faulty transceiver or cable in port %s. Error :%s.
ifName (STRING): Name of the network interface.
error_string (STRING): module event error string.
Looking for answers?
Try Doc, our Gen AI Assistant.
