netif.sfpeventerrorcode events
Creating your file...
Your file is ready
netif.sfpEventErrorCode
- Severity
ERROR
- Description
This message occurs when the installed Small Form-factor Pluggable (SFP+ or QSFP+) module is either not supported or faulty.
- Corrective Action
The cable could be unsupported or faulty. Replace the cable and check the switch port configuration for errors.
- Syslog Message
Unsupported or faulty transceiver or cable in port %s. Error :%s.
- Parameters
ifName (STRING): Name of the network interface.
error_string (STRING): module event error string.
