The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
netif.sfpeventerrorcode events
Creating your file...
Your file is ready
netif.sfpEventErrorCode
- Severity
ERROR
- Description
This message occurs when the installed Small Form-factor Pluggable (SFP+ or QSFP+) module is either not supported or faulty.
- Corrective Action
The cable could be unsupported or faulty. Replace the cable and check the switch port configuration for errors.
- Syslog Message
Unsupported or faulty transceiver or cable in port %s. Error :%s.
- Parameters
ifName (STRING): Name of the network interface.
error_string (STRING): module event error string.
