cmpr.algo events
Creating your file...
Your file is ready
cmpr.algo.not.enabled
- Severity
ALERT
- Description
This message occurs when compression algorithm specified has not been enabled on the node.
- Corrective Action
Contact technical support.
- Syslog Message
Volume '%s' has '%s' compression enabled but the necessary bootarg(s) have not been set on the node.
- Parameters
vol (STRING): Volume name.
comp_algo (STRING): Compression Algorithm.
