ONTAP EMS reference
cmpr.algo events
cmpr.algo EMS events occur when compression algorithm specified has not been enabled on the node.
cmpr.algo.not.enabled
Severity
ALERT
This message occurs when compression algorithm specified has not been enabled on the node.
Corrective Action
Contact technical support.
Syslog Message
Volume '%s' has '%s' compression enabled but the necessary bootarg(s) have not been set on the node.
vol (STRING): Volume name.
comp_algo (STRING): Compression Algorithm.
