      cmpr.algo events
cmpr.algo.not.enabled
- Severity
ALERT
 - Description
This message occurs when compression algorithm specified has not been enabled on the node.
 - Corrective Action
Contact technical support.
 - Syslog Message
Volume '%s' has '%s' compression enabled but the necessary bootarg(s) have not been set on the node.
 - Parameters
vol (STRING): Volume name.
comp_algo (STRING): Compression Algorithm.
