The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
cmpr.algo events
Creating your file...
Your file is ready
cmpr.algo.not.enabled
- Severity
ALERT
- Description
This message occurs when compression algorithm specified has not been enabled on the node.
- Corrective Action
Contact technical support.
- Syslog Message
Volume '%s' has '%s' compression enabled but the necessary bootarg(s) have not been set on the node.
- Parameters
vol (STRING): Volume name.
comp_algo (STRING): Compression Algorithm.
