ONTAP EMS reference
configbr.distributefailed events
configbr.distributeFailed
Severity
ERROR
This message occurs when a configuration backup cannot be distributed to another node in the cluster.
Corrective Action
Ensure that the destination node is accessible and healthy. If necessary, upload the backup file to the remote URL to increase the availability of the backup file with the (privilege: advanced) "system configuration backup upload" command.
Syslog Message
Configuration backup %s cannot be distributed to node %s. Error: '%s'.
backup (STRING): Backup file.
destination_node (STRING): Destination node to which the backup file failed to be distributed.
reason (STRING): Reason for the error.
Looking for answers?
Try Doc, our Gen AI Assistant.
