vscan.rdbupdregister events
vscan.rdbUpdRegister.failed
Severity
ERROR
This message occurs when the Vscan configuration replication mechanism fails to register RDB update callback. Modifications made to the Vscan configuration might not be available to this node.
Corrective Action
Perform a takeover and giveback of the node or reboot the node. For additional options, contact NetApp technical support.
Syslog Message
Vscan configuration replication mechanism failed to register RDB update callback. Modifications made to the Vscan configuration might not be available to this node.
(None).
