vscan.rdbupdregister events
vscan.rdbUpdRegister.failed
- Severity
ERROR
- Description
This message occurs when the Vscan configuration replication mechanism fails to register RDB update callback. Modifications made to the Vscan configuration might not be available to this node.
- Corrective Action
Perform a takeover and giveback of the node or reboot the node. For additional options, contact NetApp technical support.
- Syslog Message
Vscan configuration replication mechanism failed to register RDB update callback. Modifications made to the Vscan configuration might not be available to this node.
- Parameters
(None).
