km.cluster events
km.cluster.okm.hierarchy.bad
- Severity
ALERT
- Description
This message occurs in a MetroCluster(tm) configuration, when one or both clusters have been configured with the Onboard Key Manager, but one or both of the Onboard Key Manager key hierarchies are corrupted. Specifically, the 'hashed_pass' object does not match the 'hashed_pass_l' object in at least one cluster.
- Corrective Action
Reboot each of the nodes in the MetroCluster configuration.
- Syslog Message
This cluster is part of a MetroCluster configuration. The Onboard Key Manager key hierarchy on one or both of the clusters is corrupted. Specifically, the 'hashed_pass' object does not match the 'hashed_pass_l' object, part of the 'cluster_kdb' table, in either cluster.
- Parameters
(None).
