ONTAP EMS reference
km.cluster events
km.cluster EMS events occur in a MetroCluster(tm) configuration, when one or both clusters have been configured with the Onboard Key Manager, but one or both of the Onboard Key Manager key hierarchies are corrupted.
km.cluster.okm.hierarchy.bad
Severity
ALERT
This message occurs in a MetroCluster(tm) configuration, when one or both clusters have been configured with the Onboard Key Manager, but one or both of the Onboard Key Manager key hierarchies are corrupted. Specifically, the 'hashed_pass' object does not match the 'hashed_pass_l' object in at least one cluster.
Corrective Action
Reboot each of the nodes in the MetroCluster configuration.
Syslog Message
This cluster is part of a MetroCluster configuration. The Onboard Key Manager key hierarchy on one or both of the clusters is corrupted. Specifically, the 'hashed_pass' object does not match the 'hashed_pass_l' object, part of the 'cluster_kdb' table, in either cluster.
(None).
