ONTAP EMS reference
rdmalib.duplicateid events
rdmalib.duplicateid EMS events occur when the local node system identifier matches the partner node's system identifier.
rdmalib.duplicateId
Severity
ALERT
This message occurs when the local node system identifier matches the partner node's system identifier.
Corrective Action
Contact NetApp technical support.
Syslog Message
Interconnect : Partner ID %u is the same as our id.
id (INT): System Id
