The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
rdmalib.duplicateid events
Creating your file...
Your file is ready
rdmalib.duplicateId
- Severity
ALERT
- Description
This message occurs when the local node system identifier matches the partner node's system identifier.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
Interconnect : Partner ID %u is the same as our id.
- Parameters
id (INT): System Id
